[OpenLayers-Users] Result of expression 'map' [undefined] is not an object.
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Sun Oct 4 08:42:51 EDT 2009
Hi all,
I'm getting the following error in what used to be functional code Result of
It's breaking on the statement map.addLayer(cities). Here's the exerpted
code that I've added around this. I can add a stripped down version of the
rest, but it's bulky and I've only messed with the following bits. Any
suggestions as to what's causing this error?
var styleMap = new OpenLayers.StyleMap(
{'default':OpenLayers.Util.applyDefaults(
       label: '${Name}',
       strokeWidth:1,
       strokeColor:"#CCCCCC",
       fillColor: "green",
var cities = new OpenLayers.Layer.GML ("7th Century Cities",
"data/cities.gml", {
styleMap: styleMap,
projection: new OpenLayers.Projection("EPSG:4326"),
format: OpenLayers.Format.GML,
label: "${Name}",
map.addLayer(cities);
best and thanks in advance,
Fulbright Student 2009-2010, Ukraine
nefremov at artsci.wustl.edu
c/o Halyna Yerko
Balzaka 92a, Kv 27
02232
Kyiv, Ukraine
(mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091004/32162c58/attachment.html
