[OpenLayers-Users] How obtain the vertex in openlayer
Marc Jansen
jansen at terrestris.de
Thu Oct 8 17:22:00 EDT 2009
Hi salas,
I'm not quite sure if I understand what you mean. I'd guess you want a
function that is called right after a feature is added via the control,
right?
Use the "featureAdded"-property then:
var drawpolygon = new OpenLayers.Control.DrawFeature(
featureAdded: function( /* your code here */ ).
polygonLayer, OpenLayers.Handler.Polygon,
{displayClass: 'olControlDrawFeaturePolygon'}
Regards,
Marc
fsalas schrieb:
> Hi,
> I need obtain the list of the vertex of my polygon becouse after that
> I need to pass this value to POLYGON parameters and obtain all the
> objects inside the polygon.
> I use this
> panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
> ************************************************************* This is
> the Sql for postgis **************************
> SELECT cod,tipo,empresa,the_geom
> FROM sennal
> WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677
> 23.56344,-82.31771 23.51950,-82.33468 21.03659,-85.47677
> 23.56344))',4267) and tipo = 'FV';
> How implement this ?
> Regards , salas
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
