[OpenLayers-Users] How obtain the vertex in openlayer
Marc Jansen
jansen at terrestris.de
Thu Oct 8 17:26:46 EDT 2009
Argh, typo:
that code should read
featureAdded: function( /* your code here */ ),
but of course this is still untested ;-)
Marc
Marc Jansen schrieb:
> Hi salas,
> I'm not quite sure if I understand what you mean. I'd guess you want a
> function that is called right after a feature is added via the control,
> right?
> Use the "featureAdded"-property then:
> var drawpolygon = new OpenLayers.Control.DrawFeature(
> featureAdded: function( /* your code here */ ).
> polygonLayer, OpenLayers.Handler.Polygon,
> {displayClass: 'olControlDrawFeaturePolygon'}
> Regards,
> Marc
> fsalas schrieb:
>> Hi,
>> I need obtain the list of the vertex of my polygon becouse after that
>> I need to pass this value to POLYGON parameters and obtain all the
>> objects inside the polygon.
>> I use this
>> panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
>> ************************************************************* This is
>> the Sql for postgis **************************
>> SELECT cod,tipo,empresa,the_geom
>> FROM sennal
>> WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677
>> 23.56344,-82.31771 23.51950,-82.33468 21.03659,-85.47677
>> 23.56344))',4267) and tipo = 'FV';
>> How implement this ?
>> Regards , salas
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
