[OpenLayers-Users] How obtain the vertex in openlayer
fsalas
fsalas at geocuba.cu
Sat Oct 10 15:47:41 EDT 2009
jansen,
I need that, when I finished to draw polygon, execute one function to obtain
the list of the vertex
after that I like to pass this list vertex to sql consult for obtain the
object inside this polygon.
excuse my English.
regards Salas
----- Original Message -----
To: "fsalas" <fsalas at geocuba.cu>
Cc: <users at openlayers.org>
Sent: Thursday, October 08, 2009 4:22 PM
Subject: Re: [OpenLayers-Users] How obtain the vertex in openlayer
> Hi salas,
> I'm not quite sure if I understand what you mean. I'd guess you want a
> function that is called right after a feature is added via the control,
> right?
> Use the "featureAdded"-property then:
> var drawpolygon = new OpenLayers.Control.DrawFeature(
> featureAdded: function( /* your code here */ ).
> polygonLayer, OpenLayers.Handler.Polygon,
> {displayClass: 'olControlDrawFeaturePolygon'}
> Regards,
> Marc
> fsalas schrieb:
>> Hi,
>> I need obtain the list of the vertex of my polygon becouse after that I
>> need to pass this value to POLYGON parameters and obtain all the objects
>> inside the polygon.
>> I use this
>> panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
>> ************************************************************* This is
>> the Sql for postgis **************************
>> SELECT cod,tipo,empresa,the_geom
>> FROM sennal
>> WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677
>> 23.56344,-82.31771 23.51950,-82.33468 21.03659,-85.47677
>> 23.56344))',4267) and tipo = 'FV';
>> How implement this ?
>> Regards , salas
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
