[OpenLayers-Users] How obtain the vertex in openlayer
Arnd Wippermann
arnd.wippermann at web.de
Thu Oct 8 17:32:09 EDT 2009
this is the way to get the vertexes of a polygon feature:
var theVertexes = thePolygonFeature.geometry.components[0].components;
for(var i=0;i<theVertexes.length;i++)
... theVertexes[i];
or use vectorLayer.features[0].geometry, that returns the wkt string for the
polygon feature
POLYGON((-1487158.8221094 -2661231.5764062,1878516.406875
-2504688.5425,3209132.1950781 -6653078.9410156,-1174072.7542969
-6300857.1147266,-1487158.8221094 -2661231.5764062))
Arnd
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von fsalas
Gesendet: Donnerstag, 8. Oktober 2009 23:07
An: users at openlayers.org
Betreff: [OpenLayers-Users] How obtain the vertex in openlayer
I need obtain the list of the vertex of my polygon becouse after that I need
to pass this value to POLYGON parameters and obtain all the objects inside
the polygon.
I use this
var drawpolygon = new OpenLayers.Control.DrawFeature(
polygonLayer, OpenLayers.Handler.Polygon,
{displayClass: 'olControlDrawFeaturePolygon'}
panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
************************************************************* This is the
Sql for postgis **************************
SELECT cod,tipo,empresa,the_geom
FROM sennal
WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677 23.56344,-82.31771
23.51950,-82.33468 21.03659,-85.47677 23.56344))',4267) and tipo = 'FV';
How implement this ?
Regards , salas
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091008/39ac8204/attachment.html
