[OpenLayers-Users] How obtain the vertex in openlayer
fsalas
fsalas at geocuba.cu
Sat Oct 10 16:31:31 EDT 2009
Thanks , Arnd
I tested with
var findRectangle = new OpenLayers.Control.DrawFeature(polygonLayer,OpenLayers.Handler.RegularPolygon,{
title: "Klikk eller dra ut firkant rundt objekt i kartet for å finne mer informasjon",
handlerOptions: {sides: 4, irregular: true},
displayClass: 'findRectangle' ,
displayClass: 'olControlDrawFeaturePolygon'
function findRectangleFeaturAadded(feature) {
var theVertexes = polygonLayer.features[0].geometry;
alert(theVertexes);
This function show the 4 vertex in this format POLYGON((-1487158.8221094 -2661231.5764062,1878516.406875 -2504688.5425,3209132.1950781 -6653078.9410156,-1174072.7542969 -6300857.1147266,-1487158.8221094 -2661231.5764062))
My question is : How I can obtain each vertex for example vertice[0].lat , vertice[0].long, .........
And my second question is .
In this test only draw one poligon with 4 vertex , how I implement double click for a finish the draw polygon
thanks ,
Regards Salas
----- Original Message -----
To: 'fsalas'
Cc: users at openlayers.org
Sent: Thursday, October 08, 2009 4:32 PM
Subject: AW: [OpenLayers-Users] How obtain the vertex in openlayer
this is the way to get the vertexes of a polygon feature:
var theVertexes = thePolygonFeature.geometry.components[0].components;
for(var i=0;i<theVertexes.length;i++)
... theVertexes[i];
or use vectorLayer.features[0].geometry, that returns the wkt string for the polygon feature
Arnd
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im Auftrag von fsalas
Gesendet: Donnerstag, 8. Oktober 2009 23:07
An: users at openlayers.org
Betreff: [OpenLayers-Users] How obtain the vertex in openlayer
I need obtain the list of the vertex of my polygon becouse after that I need to pass this value to POLYGON parameters and obtain all the objects inside the polygon.
I use this
var drawpolygon = new OpenLayers.Control.DrawFeature(
polygonLayer, OpenLayers.Handler.Polygon,
{displayClass: 'olControlDrawFeaturePolygon'}
panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
************************************************************* This is the Sql for postgis **************************
SELECT cod,tipo,empresa,the_geom
FROM sennal
WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677 23.56344,-82.31771 23.51950,-82.33468 21.03659,-85.47677 23.56344))',4267) and tipo = 'FV';
How implement this ?
Regards , salas
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091010/d98b3048/attachment.html
