[OpenLayers-Users] How obtain the vertex in openlayer
Arnd Wippermann
arnd.wippermann at web.de
Sat Oct 10 17:21:02 EDT 2009
Hi Salas,
use something like this to get your vertices:
function findRectangleFeaturAadded(feature)
var GeomFromText = feature.geometry;
var Msg = GeomFromText + "\n";
var theVertexes = GeomFromText.components[0].components;
for(var i=0;i<theVertexes.length;i++)
{ Msg += theVertexes[i].x + ", " + theVertexes[i].y + "\n";
alert(Msg);
findRectangleFeaturAadded(features);
with this as output:
POLYGON((796109.5644078 6668910.3633327,796223.32420378
6668942.9087861,796219.44263594 6668874.8320578,796171.37091113
6668860.7986972,796109.5644078 6668910.3633327))
796109.5644078, 6668910.3633327
796223.32420378, 6668942.9087861
796219.44263594, 6668874.8320578
796171.37091113, 6668860.7986972
To build your sql you can pass feature.geometry instead of the polygon
vertices.
Your second question I don't understand.
Perhaps add
featureAdded: function (feature){ findRectangleFeaturAadded(feature) },
to your control options. This should call findRectangleFeaturAadded after a
feature is added.
Regards
Arnd
_____
Von: fsalas [mailto:fsalas at geocuba.cu]
Gesendet: Samstag, 10. Oktober 2009 22:32
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] How obtain the vertex in openlayer
Thanks , Arnd
I tested with
var findRectangle = new
OpenLayers.Control.DrawFeature(polygonLayer,OpenLayers.Handler.RegularPolygo
n,{
title: "Klikk eller dra ut firkant rundt objekt i kartet for å finne mer
informasjon",
handlerOptions: {sides: 4, irregular: true},
displayClass: 'findRectangle' ,
displayClass: 'olControlDrawFeaturePolygon'
function findRectangleFeaturAadded(feature) {
var theVertexes = polygonLayer.features[0].geometry;
alert(theVertexes);
This function show the 4 vertex in this format POLYGON((-1487158.8221094
-2661231.5764062,1878516.406875 -2504688.5425,3209132.1950781
-6653078.9410156,-1174072.7542969 -6300857.1147266,-1487158.8221094
-2661231.5764062))
My question is : How I can obtain each vertex for example vertice[0].lat ,
vertice[0].long, .........
And my second question is .
In this test only draw one poligon with 4 vertex , how I implement double
click for a finish the draw polygon
thanks ,
Regards Salas
----- Original Message -----
From: Arnd <mailto:arnd.wippermann at web.de> Wippermann
To: 'fsalas' <mailto:fsalas at geocuba.cu>
Sent: Thursday, October 08, 2009 4:32 PM
Subject: AW: [OpenLayers-Users] How obtain the vertex in openlayer
this is the way to get the vertexes of a polygon feature:
var theVertexes = thePolygonFeature.geometry.components[0].components;
... theVertexes[i];
or use vectorLayer.features[0].geometry, that returns the wkt string for the
polygon feature
POLYGON((-1487158.8221094 -2661231.5764062,1878516.406875
-2504688.5425,3209132.1950781 -6653078.9410156,-1174072.7542969
-6300857.1147266,-1487158.8221094 -2661231.5764062))
Arnd
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von fsalas
Gesendet: Donnerstag, 8. Oktober 2009 23:07
An: users at openlayers.org
Betreff: [OpenLayers-Users] How obtain the vertex in openlayer
I need obtain the list of the vertex of my polygon becouse after that I need
to pass this value to POLYGON parameters and obtain all the objects inside
the polygon.
I use this
var drawpolygon = new OpenLayers.Control.DrawFeature(
polygonLayer, OpenLayers.Handler.Polygon,
{displayClass: 'olControlDrawFeaturePolygon'}
panel.addControls([new OpenLayers.Control.Navigation(), drawpolygon]);
************************************************************* This is the
Sql for postgis **************************
SELECT cod,tipo,empresa,the_geom
FROM sennal
WHERE sennal.the_geom && GeomFromText('POLYGON((-85.47677 23.56344,-82.31771
23.51950,-82.33468 21.03659,-85.47677 23.56344))',4267) and tipo = 'FV';
How implement this ?
Regards , salas
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091010/bdd7c21f/attachment.html
