[OpenLayers-Users] getFeatureInfo & event.text
Monty
carlos.montalvillo at gmail.com
Fri Oct 9 11:25:52 EDT 2009
Alexandre,
I don't really know...
I´m using version 2.8.
So, when testing my geoserver, I can use this url :
http://www.ddond.com:8080/geoserver/wms?bbox=-1.8199148654937751,43.17675437927251,-1.130132150650025,43.71184120178219&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=sf:communes&width=800&height=582&srs=EPSG:4326
Here
... I can read data from database.
So, I can't read these values with html pages placed outside the port :8080
I think is (may be) a misconfiguration from my system, so I'm really stopped
: I don't know how can I do to solve this...
Any help would be great for me.
Merci,
Monty
Alexandre Dube wrote:
> Hi Monty,
> What is the OpenLayers version you are using ? Could your problem be
> related to the following ticket ? If so, it's fixed in trunk so either
> try the trunk version or apply the patch in the ticket :
> http://trac.openlayers.org/ticket/2201
> Regards,
> Alexandre
> Monty wrote:
>> Somebody has the same problem ?
>> Thanks,
>> Carlos
>> Monty wrote:
>>> Hi all,
>>> I'm trying to create a popup for my openlayers map using :
>>> eventListeners:
>>> { getfeatureinfo: function(event)
>>> {map.addPopup(
>>> new OpenLayers.Popup.
>>> FramedCloud(
>>> "chicken",
>>> map.getLonLatFromPixel(event.xy),
>>> null,
>>> event.text,
>>> null,
>>> true
>>> So, the result for clicking objects in the map is allways "parameter
>>> FORMAT is required"
>>> You can test it at "http://www.ddond.com/GeoBidasoa/Bidasoa.html
>>> Any ideas ?
>>> Thanks for your help,
>>> Carlos
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/getFeatureInfo-event-text-tp3792949p3795346.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091009/351b1b5d/attachment.html
