[OpenLayers-Users] getFeatureInfo & event.text
Alexandre Dube adube at mapgears.com
Fri Oct 9 13:40:26 EDT 2009
Monty,
  Maybe your problem is more related to the query sent to GeoServer.  I
don't know anything about it, so I can't really help, but testing a
request outside OL seems to return an empty <body>...  See the source of :
http://www.ddond.com:8080/geoserver/wms?HEIGHT=582&WIDTH=800&LAYERS=sf%3Acommunes&STYLES=&SRS=EPSG%3A4326&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=-2.013916%2C43.052253%2C-0.936131%2C43.836342&X=388&Y=368&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=sf%3Acommunes&FEATURE_COUNT=50
Don't know if that can help,
Best of luck,
Alexandre
Monty wrote:
> Alexandre, I don't really know... I´m using version 2.8. So, when
> testing my geoserver, I can use this url : Here
> <http://www.ddond.com:8080/geoserver/wms?bbox=-1.8199148654937751,43.17675437927251,-1.130132150650025,43.71184120178219&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=sf:communes&width=800&height=582&srs=EPSG:4326>
> ... I can read data from database. So, I can't read these values with
> html pages placed outside the port :8080 I think is (may be) a
> misconfiguration from my system, so I'm really stopped : I don't know
> how can I do to solve this... Any help would be great for me. Merci,
> Monty
>     Alexandre Dube wrote:
>     Hi Monty, What is the OpenLayers version you are using ? Could
>     your problem be related to the following ticket ? If so, it's
>     fixed in trunk so either try the trunk version or apply the patch
>     in the ticket : http://trac.openlayers.org/ticket/2201 Regards,
>     Alexandre Monty wrote: > Somebody has the same problem ? > >
>     Thanks, > > Carlos > > > Monty wrote: > >> Hi all, >> >> I'm
>     trying to create a popup for my openlayers map using : >> >>
>     eventListeners: >> { getfeatureinfo: function(event) >>
>     {map.addPopup( >> new OpenLayers.Popup. >> FramedCloud( >>
>     "chicken", >> map.getLonLatFromPixel(event.xy), >> null, >>
>     event.text, >> null, >> true >> )); >> } >> } >> }); >> >> So, the
>     result for clicking objects in the map is allways "parameter >>
>     FORMAT is required" >> >> You can test it at
>     "http://www.ddond.com/GeoBidasoa/Bidasoa.html >> >> Any ideas ? >>
>     >> Thanks for your help, >> >> Carlos >> >> >> > > -- Alexandre
>     Dubé Mapgears www.mapgears.com
>     _______________________________________________ Users mailing list
>     Users at openlayers.org http://openlayers.org/mailman/listinfo/users
> View this message in context: Re: getFeatureInfo & event.text
> <http://n2.nabble.com/getFeatureInfo-event-text-tp3792949p3795346.html>
> Sent from the OpenLayers Users mailing list archive
> <http://n2.nabble.com/OpenLayers-Users-f1822463.html> at Nabble.com.
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
