[OpenLayers-Users] OpenLayers and Tilecache doesn't work with
"mergeNewParams" Parameter
Marc Jansen
jansen at terrestris.de
Mon Oct 12 08:09:55 EDT 2009
Hi Hanno,
is there any chance that the URL- parameter SLD is not being forwarded
to your mapserver? Maybe you can check any log files of either Tilecache
or Mapserver.
Regards,
Marc
Rahn Hanno (rahn) schrieb:
> Hello list,
> I still have a problem with my TileCache configuration. I try
> something out but it doesn’t work. I think it is a problem with the
> mergeNewParams Parameter in OpenLayers. All other layers work but the
> layer with the mergeNewParams doesn’t. As new Param I get a php-Skript
> which generates an SLD-File for styling the map. I hope you can help
> me again. Without TileCache all works fine. And all layers without the
> mergeNewParams works, too. With the mergeNewParams Parameter I only
> get white Tiles without any error message. At the Server there are
> white png-files in the output Directory from Tilecache.
> Here are my code fragments. Perhaps you can see the error. I think my
> resolutions and my extents are ok.
> _Tilecache.cfg_
> [gemeinden_2008]
> type=WMS
> url=http://webgis.hsw.ch/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/GINES/Maps/Gemeinden_Bern.map
> #mapfile=C:/ms4w/Apache/htdocs/GINES/Maps/Gemeinden_Bern.map
> layers=gemeinden_2008
> maxresolution=481.8359375
> minresolution=0.0009190291166305542
> resolutions=481.8359375, 240.91796875, 120.458984375, 60.2294921875,
> 30.11474609375, 15.057373046875, 7.5286865234375, 3.76434326171875,
> 1.882171630859375, 0.9410858154296875, 0.47054290771484375,
> 0.23527145385742188, 0.11763572692871094, 0.058817863464355469,
> 0.029408931732177734, 0.014704465866088867, 0.0073522329330444336,
> 0.0036761164665222168, 0.0018380582332611084, 0.0009190291166305542
> levels=5
> extension=png
> extent_type=loose
> srs=EPSG:21781
> bbox=555100,129900,678450,245000
> metaTile=true
> _OpenLayers_
> _ _
> var url = "http://webgis.hsw.ch/GINES/Styling/mysld_bezirke.php?";
> var urlFusion = "http://webgis.hsw.ch/GINES/Styling/mysld_fusion.php?";
> var urlArray = ["http://webgis.hsw.ch/cgi-bin/mapserv.exe?",
> "http://195.176.253.211/cgi-bin/mapserv.exe?"];
> var urlArrayTC =
> ["http://webgis.hsw.ch/cgi-bin/tilecache/tilecache.cgi?"];
> var mapFile = "../htdocs/GINES/Maps/Gemeinden_Bern.map";
> var options1 = {
> maxExtent: new OpenLayers.Bounds(555100,129900,678450,245000),
> maxScale: '500',
> minScale: '458262',
> resolutions:[481.8359375, 240.91796875, 120.458984375, 60.2294921875,
> 0.0036761164665222168, 0.0018380582332611084, 0.0009190291166305542],
> maxresolution:481.8359375,
> minresolution:0.0009190291166305542,
> units: 'm',
> projection: "EPSG:21781",
> controls: []
> var map = new OpenLayers.Map('map',options1);
> var wms = new OpenLayers.Layer.WMS("Gemeinden",urlArrayTC,
> {map:mapFile,layers:layerName,format:"image/png",EXCEPTIONS:"application/vnd.ogc.se_inimage"}
> var
> sld_string=url+"jahr="+jahr+"&indikator="+indikator1+"&klassen="+klassen+"&vis="+vis+"&fusion="+jahr4+"&farbe="+farbe;
> wms.mergeNewParams({ SLD:sld_string});
> Greetings
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
