[OpenLayers-Users] Moveend event results in endless loop
Alexandre Dube
adube at mapgears.com
Tue Oct 13 09:03:14 EDT 2009
Hi Dragan,
Using firebug and putting a breakpoint to your map.zoomToExtent(bbox),
what does it looks like ?
Alexandre
Dragan Podvezanec wrote:
> Hi all. I have small problem with moveend event: I have two layers, WMS (as
> base layer), and WFS. Both are served by Geoserver. What I want to do is:
> after searching for an object from WFS layer, I want to Pan the map to
> center of this object, and then zoom to it's extents. Here is the part of
> the code:
> wfs.events.register("loadend", wfs, function() {
> var bbox = wfs.getDataExtent();
> map.panTo(bbox.getCenterLonLat());
> alert("Centered");
> wms.events.register("moveend", wms, function()
> alert(bbox);
> //map.zoomToExtent(bbox);
> As you see, zoomToExtent is commented. This way map pans to center of the
> WFS object and I have the alert with bbox. But, if I uncomment
> map.zoomToExtent(bbox); , I keep getting this alert with bbox, and map never
> zooms to bbox. What am I doing wrong here?
Alexandre Dubé
Mapgears
www.mapgears.com
