[OpenLayers-Users] Featureserver + Openlayers
goliah
bianchimro at gmail.com
Wed Oct 14 05:52:23 EDT 2009
Thanks Eric,
I find mapfish very interesting and I think I'll switch soon to it (being an
openlayers user and knowing some bits of Pylons).
What scares me a bit is that (as long as I understood from a quick look in
the wiki) setting up a WFS is not as easy as writing a config file for
feature server, but obviusly you must pay something in order to gain some
flexibility.
I'm going to subscribe soon to the mapfish mailing list, so maybe I'll ask
for some help there.
Thanks again!
Cheers
Mauro
Eric Lemoine-2-2 wrote:
> On Tuesday, October 13, 2009, goliah <bianchimro at gmail.com> wrote:
>> Thanks Alexandre,
>> I'll check it out.
>> Do you think I should switch to a mapfish server for a production app?
>> It seems like it is more mantained.
> Hi. I guess it depends on your needs. If FeatureServer just does the
> job for you then I don't much benefit in switching to MapFish (except
> maybe that we always make sure that client and server speak the same
> language in MapFish). If you need to customize your web services then
> use MapFish - MapFish is a framework for creating applications, an
> application created with MapFish belongs to the developer, who is free
> to modify his application and his application's web services to meet
> his needs. It is also important to note that MapFish only supports
> PostGIS as the data store at this time, support for MySQL and
> Spatialite are in the plans.
> Hope this helps,
> Eric
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Featureserver-Openlayers-tp3797197p3821628.html
