[OpenLayers-Users] Control access to WMS
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed Oct 14 09:53:40 EDT 2009
Thanks all for your help,
I'll have in a near future to implement a fully secured private site since
I'm gonna have to publish VERY sensible data via WMS. I can tell that this
issue scares the IT group. Story to follow...
But for now, obscurity is sufficient.
I'm a bit in obscurity myself regardin http_referer...I need to know more
about the mechanic...
It's not clear what I should do in the mapfile and in my OpenLayers code?
I added Daniel's code in Apache conf.
"Then your WMS requests should refer to the mapfile using "map=MYMAP"
instead of a full path. If the referrer is not valid, then MYMAP will
not be set and MapServer will spit out an error."
Do I need to use the MYMAP environment variabble in the mapfile or in OL
code, or both?
I'm using OpenLayers to create a WMS layer with new
OpenLayers.Layer.WMS(name, url, params, options);
Instead of the path of the mapfile should I use MYMAP (Environment
variable MYMAP defined in the conf of Apache). If so, Is there some magic
there to get the environment variable value? Should I get it with some php
code?
Thanks
Steve
Daniel Morissette <dmorissette at mapgears.com>@openlayers.org
Envoyé par : users-bounces at openlayers.org
13/10/2009 02:56 PM
A
users at openlayers.org
cc
Objet
Re: [OpenLayers-Users] Control access to WMS
Christopher Schmidt wrote:
> If you care about people 'stumbling in', this would be sufficient. If
you
> actually want to ensure people can't use the data outside of your app,
> it's not.
> Yeah, something like that is what I would probably do if I wanted
something
> taht was obscurity and not security. :)
I agree (and I never used the word security). But this may be sufficient
in some simple cases.  :)
And for a more complete Access Control solution, everyone is invited to
a presentation of the new GeoPrisma project in a conference near you:
FOSS4G 2009 (Sydney, 2009-10-23):
   http://2009.foss4g.org/presentations/#presentation_146
Géomatique 2009 (Montréal, 2009-10-21):
   http://www.geomatique2009.com/en/papers/program
Daniel
Daniel Morissette
http://www.mapgears.com/
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091014/8a2e9869/attachment.html
