[OpenLayers-Users] Problems displaying popup
Marc Jansen jansen at terrestris.de
Wed Oct 14 11:01:25 EDT 2009
David
please reply to the list.
I forwarded your mail.
Regards,
Marc
David Alda Fernandez de Lezea schrieb:
> Hello,
> Ok, definitely today is not my best day. My map is in meters an in Projection EPSG:23030. I've just test the app using the function OpenLayers.getLonLatFromPixel, and finally the pop up appears, but it doesn't appear on the correct place.It appears a bit more far from the point I've clicked on.Looking at the documentation I've found this function but it doesn't say what's its objective 'getViewPortPxFromLayerPx'. Should I use this function?
> Thanks.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
> email: dalda at ikt.es                                web: www.ikt.es
> -----Mensaje original-----
> De: Marc Jansen [mailto:jansen at terrestris.de]
> Enviado el: miércoles, 14 de octubre de 2009 16:07
> Para: David Alda Fernandez de Lezea
> CC: users at openlayers.org
> Asunto: Re: [OpenLayers-Users] Problems displaying popup
> Hi David,
> are posx and posy in the same units as the maps' projection demands it?
> What does (using the Firefox Plugin Firebug) console.log(popup) show?
> Regards,
> Marc
>> Hello, I'm having some troubles trying to show a popup in openlayers.
>> I'm using this code in the map:
>> var popup = new OpenLayers.Popup("chicken", new
>> OpenLayers.LonLat(posx,posy),new OpenLayers.Size(200,200),"Example
>> Popup",true); map.addPopup(popup);
>> where posx and posy are 2 variables that are NOT NULL. I've tested it.
>> but the popup doesn't appear anywhere.
>> I've already gone to de the documentation and copy paste the code that
>> is provided and still not working.
>> What's going on? I'm doing something wrong??
>> Thanks
>> Un saludo,
>> *David Alda Fernández de Lezea*
>> Biodiversidad
>> *IKT*
>> <mailto:dalda at ikt.es>                                web: www.ikt.es
>> <http://www.ikt.es/>
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
