[OpenLayers-Users] Problems displaying popup
David Alda Fernandez de Lezea
dalda at ikt.es
Wed Oct 14 11:03:07 EDT 2009
Hello,
Ok, definitely today is not my best day. My map is in meters an in Projection EPSG:23030. I've just test the app using the function OpenLayers.getLonLatFromPixel, and finally the pop up appears, but it doesn't appear on the correct place.It appears a bit more far from the point I've clicked on.Looking at the documentation I've found this function but it doesn't say what's its objective 'getViewPortPxFromLayerPx'. Should I use this function?
Thanks.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
-----Mensaje original-----
De: Marc Jansen [mailto:jansen at terrestris.de] Enviado el: miércoles, 14 de octubre de 2009 16:07
Para: David Alda Fernandez de Lezea
CC: users at openlayers.org
Asunto: Re: [OpenLayers-Users] Problems displaying popup
Hi David,
are posx and posy in the same units as the maps' projection demands it?
What does (using the Firefox Plugin Firebug) console.log(popup) show?
Regards,
Marc
David Alda Fernandez de Lezea schrieb:
> Hello, I'm having some troubles trying to show a popup in openlayers.
> I'm using this code in the map:
> var popup = new OpenLayers.Popup("chicken", new
> OpenLayers.LonLat(posx,posy),new OpenLayers.Size(200,200),"Example
> Popup",true); map.addPopup(popup);
> where posx and posy are 2 variables that are NOT NULL. I've tested it.
> but the popup doesn't appear anywhere.
> I've already gone to de the documentation and copy paste the code that
> is provided and still not working.
> What's going on? I'm doing something wrong??
> Thanks
> Un saludo,
> *David Alda Fernández de Lezea*
> Biodiversidad
> *IKT*
> <mailto:dalda at ikt.es> web: www.ikt.es
> <http://www.ikt.es/>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
