[OpenLayers-Users] Share created function about SLD Filters
fsalas fsalas at geocuba.cu
Wed Oct 14 12:01:18 EDT 2009
Hi ,
We have been at work with the filters of layers and we like tho share the created functions. We hoped that help to them.
//Function for apply filters on WMS Layers using selecting value, the main objetive of this function is make one sld and then //apply to point layers, although with some simple modification is extensive to another layers Ej. Polygon.....
//*****  Function for make one filter of point layer ***********//
function  Crear_PropertyIsEqualTo(pPropertyName,pLiteral)
 var PropertyIsEqualTo = '<PropertyIsEqualTo>';
     PropertyIsEqualTo += '<PropertyName>'+pPropertyName+'</PropertyName>';
     PropertyIsEqualTo += '<Literal>'+pLiteral+'</Literal>';
  PropertyIsEqualTo += '</PropertyIsEqualTo>';
  return PropertyIsEqualTo;
// this function make one properties for filters
function  Crear_PropertyIsLessThanOrEqualTo(pPropertyName,pLiteral)
 var PropertyIsLessThanOrEqualTo = '<PropertyIsLessThanOrEqualTo>';
     PropertyIsLessThanOrEqualTo += '<PropertyName>'+pPropertyName+'</PropertyName>';
     PropertyIsLessThanOrEqualTo += '<Literal>'+pLiteral+'</Literal>';
  PropertyIsLessThanOrEqualTo += '</PropertyIsLessThanOrEqualTo>';
  return PropertyIsLessThanOrEqualTo;
function  Crear_PropertyIsGreaterThanOrEqualTo(pPropertyName,pLiteral)
 var PropertyIsGreaterThanOrEqualTo = '<PropertyIsGreaterThanOrEqualTo>';
     PropertyIsGreaterThanOrEqualTo += '<PropertyName>'+pPropertyName+'</PropertyName>';
     PropertyIsGreaterThanOrEqualTo += '<Literal>'+pLiteral+'</Literal>';
  PropertyIsGreaterThanOrEqualTo += '</PropertyIsGreaterThanOrEqualTo>';
  return PropertyIsGreaterThanOrEqualTo;
// thsi function make one filters for inside SLD using the propperties list meke before
function Crear_Filter(Lista_Propertys,Cantidad)
 var Filter = '<Filter xmlns:gml="http://www.opengis.net/gml">';
   if(Cantidad == 0)
    Filter = '';
    else if(Cantidad == 1)
     Filter += Lista_Propertys;
  Filter += '</Filter>';
 else
     Filter += '<And>';
     for( var i = 0;i < Cantidad ;i++)
    Filter += Lista_Propertys[i];
  Filter += '</And>';
   return Filter;
// This function return the image name that wil be show in the SLD simbology
function GetImagen()
  if(document.getElementById('tipo_anav').value != "-1")
     if(document.getElementById('tipo_anav').value == "FV")
    return "FV.gif";
     if(document.getElementById('tipo_anav').value == "FA")
    return "FA.gif";
     if(document.getElementById('tipo_anav').value == "BY")
    return "BY.gif";
     if(document.getElementById('tipo_anav').value == "BZ")
    return "BZ.gif";
     if(document.getElementById('tipo_anav').value == "ENF")
    return "ENF.gif";
  else
    return "FV.gif";
// This function create the Rule contained into the SLD
function Crear_Rule(pFilter)
 var Rule ='<Rule>';
  if(pFilter != '')
   Rule += pFilter;
  Rule +='<PointSymbolizer><Graphic><ExternalGraphic><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="file:/D:/AppServ/www/SIGANAV/images/'+GetImagen()+'"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer>';
  Rule +='</Rule>';
 return Rule;
// This function create the SLD using the rule
function Crear_StyledLayerDescriptor(pRule)
   var StyledLayerDescriptor;
  StyledLayerDescriptor ='<StyledLayerDescriptor version="1.0.0"><UserLayer><Name>topp:sennal</Name><UserStyle><Name>UserSelection</Name><FeatureTypeStyle>'+pRule+'</FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>';
  return StyledLayerDescriptor;
// This function is one example tha How filter the layer using the selecting elements
function FiltrarCapa()
  var listaPropiedades = new Array();
  var Cant = 0;
  if(document.getElementById('emp').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('empresa',document.getElementById('emp').value );
  if(document.getElementById('est').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('estacion',document.getElementById('est').value );
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('tipo_senal',document.getElementById('tipo_anav').value );
  if(document.getElementById('categoria').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('categoria',document.getElementById('categoria').value );
  if(document.getElementById('ciega').checked == true)
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('ciega_luminica','C');
  if(document.getElementById('luminica').checked == true)
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('ciega_luminica','L');
 if(document.getElementById('sennal_fuera_serv').checked == true)
    var valor = "true";
listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('fuera_servicio',valor);
       if(document.getElementById('fecha_ini').value != "")
    listaPropiedades[Cant++] = Crear_PropertyIsLessThanOrEqualTo('fecha_falla',document.getElementById('fecha_ini').value );
       if(document.getElementById('fecha_fin').value != "")
    listaPropiedades[Cant++] = Crear_PropertyIsGreaterThanOrEqualTo('fecha_falla',document.getElementById('fecha_fin').value );
       if(document.getElementById('tipo_falla').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('tipo_falla',document.getElementById('tipo_falla').value );
   if(document.getElementById('origen_falla').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('origen_falla',document.getElementById('origen_falla').value );
  if(document.getElementById('mant_plan').checked == true)
       if(document.getElementById('fecha_ini').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsLessThanOrEqualTo('fecha_mant_planificado',document.getElementById('fecha_ini').value );
       if(document.getElementById('fecha_fin').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsGreaterThanOrEqualTo('fecha_mant_planificado',document.getElementById('fecha_fin').value );
       if(document.getElementById('tipo_mant').value != "-1")
    listaPropiedades[Cant++] = Crear_PropertyIsEqualTo('tipo_mant_realizado',document.getElementById('tipo_mant').value );
  if(document.getElementById('mant_ejec').checked == true)
    listaPropiedades[Cant++] = Crear_PropertyIsLessThanOrEqualTo('fecha_mant_realizado',document.getElementById('fecha_ini').value );
    listaPropiedades[Cant++] = Crear_PropertyIsGreaterThanOrEqualTo('fecha_mant_realizado',document.getElementById('fecha_fin').value );
//********************** Example of Call this functions     ************************//
   var Filtro = Crear_Filter(listaPropiedades,Cant);
   var Regla  = Crear_Rule(Filtro);
   var StyledLayerDescriptor = Crear_StyledLayerDescriptor(Regla);
   map.layers[2].mergeNewParams({SLD_BODY:StyledLayerDescriptor});
Best Regards , Salas
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091014/f34b998a/attachment.html
