[OpenLayers-Users] Catching WMS Exceptions
    bartvde at osgis.nl
    bartvde at osgis.nl
    Thu Oct 15 06:22:00 EDT 2009
check out OpenLayers.Util.onImageLoadError
Best regards,
Bart
> Hi,
> I use GeoServer as WMS service provider. Does exist the possibility to add
> a
> listener to the OpenLayers.Layer.WMS
> object in order to catch the 'onerror' event ? I noticed that the
> 'onerror'
> event is not present in the OpenLayers.Map.
> Best regards,
> Tobia Di Pisa
> 2009/10/15 <bartvde at osgis.nl>
>> Hi,
>> I don't think you can currently. You can use onerror of the img, but it
>> won't give you the contents.
>> A way would be loading the images through AJAX, which has disadvantages
>> as
>> well (same origin policy and needs changes to OpenLayers).
>> Maybe the new WMS POST layer has a facility for this, but I don't know
>> if
>> your WMS service supports POST?
>> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Layer/WMS/Post.js
>> Best regards,
>> Bart
>> > Hi all,
>> > I have to effect the WMS requests specifying as parameter '
>> exceptions:
>> > "application/vnd.ogc.se_xml" ' insteed ' exceptions:
>> > "application/vnd.ogc.se_inimage" '.
>> > How can I catch the server response in the case that the exception is
>> > verified?
>> > Regards,
>> >       Tobia Di Pisa
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
