[OpenLayers-Users] Catching WMS Exceptions
    Tobia Di Pisa
    tobia.dipisa at geo-solutions.it
    Thu Oct 15 06:11:44 EDT 2009
I use GeoServer as WMS service provider. Does exist the possibility to add a
listener to the OpenLayers.Layer.WMS
object in order to catch the 'onerror' event ? I noticed that the 'onerror'
event is not present in the OpenLayers.Map.
Best regards,
Tobia Di Pisa
2009/10/15 <bartvde at osgis.nl>
> Hi,
> I don't think you can currently. You can use onerror of the img, but it
> won't give you the contents.
> A way would be loading the images through AJAX, which has disadvantages as
> well (same origin policy and needs changes to OpenLayers).
> Maybe the new WMS POST layer has a facility for this, but I don't know if
> your WMS service supports POST?
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Layer/WMS/Post.js
> Best regards,
> Bart
> > Hi all,
> > I have to effect the WMS requests specifying as parameter ' exceptions:
> > "application/vnd.ogc.se_xml" ' insteed ' exceptions:
> > "application/vnd.ogc.se_inimage" '.
> > How can I catch the server response in the case that the exception is
> > verified?
> > Regards,
> >       Tobia Di Pisa
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091015/3d04fef8/attachment.html
