[OpenLayers-Users] Event/Msg when all LayerPics are loaded?
Bytechanger
Bytechanger at gmx.de
Thu Oct 15 09:06:55 EDT 2009
thanks,
but when the LoadingPanel-Layer is shown, then I can´t select a marker
(Popup) on an other
layer...
Greetings
Byte
bartvde wrote:
> There is the loadend event on a per layer basis.
> There is also the addin called LoadingPanel which automates this for you.
> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> Best regards,
> Bart
>> Hi,
>> I load a map from a WMS-Server or local png data.
>> Is there a event or something else, wich tells me, that
>> all pics are loaded???
>> (Sometimes it takes very long...)
>> Greetings
>> Byte
>> View this message in context:
>> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828940.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3829182.html
