[OpenLayers-Users] Event/Msg when all LayerPics are loaded?
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Oct 15 11:21:52 EDT 2009
I'll see if I can find some time in Sydney to rewrite the loading panel
so that it is not blocking.
Best regards,
Bart
Bytechanger wrote:
> Hi,
> thanks,
> but when the LoadingPanel-Layer is shown, then I canĀ“t select a marker
> (Popup) on an other
> layer...
> Greetings
> Byte
> bartvde wrote:
>> There is the loadend event on a per layer basis.
>> There is also the addin called LoadingPanel which automates this for you.
>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>> Best regards,
>> Bart
>>> Hi,
>>> I load a map from a WMS-Server or local png data.
>>> Is there a event or something else, wich tells me, that
>>> all pics are loaded???
>>> (Sometimes it takes very long...)
>>> Greetings
>>> Byte
>>> View this message in context:
>>> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828940.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
