[OpenLayers-Users] Event/Msg when all LayerPics are loaded?
Bytechanger
Bytechanger at gmx.de
Fri Oct 16 02:07:48 EDT 2009
thanks,
I´ve shown in your code and build an own code with
xxx.events.register('loadstart', ...
But somtimes (esp. on local map) the 'loadend' event isn´t thrown, so the
loadimage is shown all the time....
or on WMS the first loading (without scrolling) theres NO 'loadstart'
event ....
BUT is there a list of ALL types of "event"-Types ??
Greetings
Byte
bartvde (via Nabble) schrieb:
> There is the loadend event on a per layer basis.
> There is also the addin called LoadingPanel which automates this for you.
> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> Best regards,
> Bart
> > Hi,
> > I load a map from a WMS-Server or local png data.
> > Is there a event or something else, wich tells me, that
> > all pics are loaded???
> > (Sometimes it takes very long...)
> > Greetings
> > Byte
> > View this message in context:
> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828940.html
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> > [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3828952&i=0>
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
> [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3828952&i=1>
> View message @
> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828952.html
> To unsubscribe from Event/Msg when all LayerPics are loaded?, click
> here
> < (link removed) =>.
View this message in context: http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3833810.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091015/5c176b7e/attachment.html
