[OpenLayers-Users] Event/Msg when all LayerPics are loaded?
Ivan Grcic igrcic at gmail.com
Sat Oct 17 07:11:04 EDT 2009
general layer event_types can be found at:
http://dev.openlayers.org/apidocs/files/OpenLayers/Layer-js.html#OpenLayers.Layer.EVENT_TYPES
but then, many different layer types have their own events defined,
like vector layer:
http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/Vector-js.html#OpenLayers.Layer.Vector.EVENT_TYPES
BTW thers tile monitoring example:
http://openlayers.org/dev/examples/layerLoadMonitoring.html
Cheers
On Fri, Oct 16, 2009 at 8:07 AM, Bytechanger <Bytechanger at gmx.de> wrote:
> Hi,
> thanks,
> I´ve shown in your code and build an own code with
>      xxx.events.register('loadstart', ...
> But somtimes (esp. on local map) the 'loadend' event isn´t thrown, so the
>  loadimage is shown all the time....
> or on WMS the first loading (without scrolling) theres NO 'loadstart'
> event ....
> BUT is there a list of ALL types of "event"-Types ??
> Greetings
> Byte
> bartvde (via Nabble) schrieb:
>> There is the loadend event on a per layer basis.
>> There is also the addin called LoadingPanel which automates this for you.
>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>> Best regards,
>> Bart
>> > Hi,
>> > I load a map from a WMS-Server or local png data.
>> > Is there a event or something else, wich tells me, that
>> > all pics are loaded???
>> > (Sometimes it takes very long...)
>> > Greetings
>> > Byte
>> > View this message in context:
>> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828940.html
>> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > Users mailing list
>> > [hidden email]
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3828952&i=0>
>> > http://openlayers.org/mailman/listinfo/users
>> Users mailing list
>> [hidden email]
>> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3828952&i=1>
>> View message @
>> http://n2.nabble.com/Event-Msg-when-all-LayerPics-are-loaded-tp3828940p3828952.html
>> To unsubscribe from Event/Msg when all LayerPics are loaded?, click
>> here
>> <<Link Removed>>.
> View this message in context: Re: [OpenLayers-Users] Event/Msg when all
> Users mailing list
> Users at openlayers.org
Ivan Grcic
