[OpenLayers-Users] Geocoding
Paul Spencer
pagameba at gmail.com
Thu Oct 15 21:26:32 EDT 2009
I've used a couple:
* http://geocoder.us - based on US Tiger/Line, for fee service or you
can get the source and build your own
* http://imaptools.com/geocode-us.html - based on US Tiger/Line, buy a
license
We are using navteq street data now for our maps and geocodes against
Tiger/Line don't align well so we currently have a home-grown solution
using imaptools address parser and our own postgis database.
There is some indication that PAGC (http://www.pagcgeo.org/) will
become more generic, supporting multiple back ends and datasets in a
cleaner way. I would probably go with PAGC if that happened.
Cheers
Paul
On 2009-10-14, at 7:09 PM, David Lozzi wrote:
> Hi Paul,
> WOW. Thanks for the insight, I've been wondering... What geocode
> service do you use?
> David Lozzi
> Product Development Manager
> Delphi Technology Solutions, Inc.
> (978) 988-8007 x204 - www.delphi-ts.com
> Blog - LinkedIn - Twitter
> -----Original Message-----
> From: Paul Spencer [mailto:pagameba at gmail.com]
> Sent: Wednesday, October 14, 2009 5:54 PM
> To: David Lozzi
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Geocoding
> This isn't a direct answer, rather I'm answering why services may be
> different and providing some guidance on geocoding based on my
> experience. Don't read on if you don't care about that.
> The short answer is that differences in location returned by different
> geocoders probably depends more on the data source being used by the
> geocoder than the geocoder itself.
> Address parsing aside, geocoding is actually a fairly straight forward
> process that probably uses one of two techniques:
> technique 1: linear interpolation
> * find the record that matches the requested street (a lot goes into
> identifying the correct street, let's leave that out)
> * find a segment of the street with a start and end address that
> contain the requested street number
> * find a point on the segment equivalent to where the requested number
> is between the start and end of the line
> What is typically different here between geocoders (assuming they find
> the same street) is the quality of the street number data (is it
> there, is it correct, is it the right way around, is it associated
> with the correct side of the street for odd/even etc) and the quality
> of the geographic line segment that represents the street.
> Some services might also use some heuristic data for adjusting the
> interpolated location from being straight linear interpolation to
> something (that may be) more accurate.
> technique 2: exact location
> if you have tax lot/parcel/cadastral data then you can find an exact
> match on a street address to a parcel associated with that address and
> return the centroid of the parcel (perhaps snapped to the appropriate
> street segment).
> The other component of a typical geocoder is its ability to parse an
> address and match it to a street segment. This can involve a lot of
> complicated steps and has to accommodate a seemingly infinite number
> of ways that addresses can be written, missing address components,
> mis-
> spellings of all parts, incorrect information such as incorrect zip
> code or wrong street type, and more.
> You need to evaluate geocoders on a couple of parameters:
> * what is the source data they are using and how 'accurate' is it?
> * is it accurate enough for you vs what you are paying for it? (a
> commercial data set might be arguably more accurate than a free one
> for instance)
> * given how your addresses are expected to supplied, how well does
> each service parse the address, accommodate missing, incorrect or mis-
> spelled data and ultimately map that to the right address
> (disregarding actual accuracy of the address)
> Typically, if you are mapping results of geocoding, you will also want
> to ensure the geocoder is using the same source data as for generating
> the maps to minimize the visual impact of differences in the quality
> of the actual street vector data. In the end, this is usually more
> important than the physical accuracy for many use cases.
> Cheers
> Paul
> On 2009-10-14, at 5:21 PM, David Lozzi wrote:
>> Hello,
>> What service are you using to geocode your addresses? I've looked at
>> a couple and I've been getting different results per set.
>> Thanks,
>> David Lozzi
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
