[OpenLayers-Users] Change Vector Point feature class styles
dynamically.
Andreas Hocevar
ahocevar at opengeo.org
Fri Oct 16 02:16:28 EDT 2009
style contexts only work in a StyleMap, not in a Style. So the best
thing to do is create a StyleMap with custom renderIntents (e.g.
"myStyle1"), and to draw a feature with that intent instead of "default"
you just say layer.drawFeature(feature, "myStyle1").
Regards,
Andreas.
Jonathan Sawyer wrote:
> I have a Vector layer being initialized with a default style. I am
> then adding new vector features (Points) dynamically via Ajax calls
> and GeoJSON data.
> Anyway, if I try to apply a non-default style to a Point dynamically
> using something similar to this code:
> /* init code */
> var defaultStyle = new OpenLayers.Style({
> pointRadius: "${radius}",
> fillColor: "#00ddff",
> fillOpacity: 1,
> strokeColor: "#008899",
> strokeWidth: 1,
> strokeOpacity: 1,
> context: {
> radius: function(feature) {
> var pix = 3;
> if (feature.cluster) {
> pix = Math.min(feature.attributes.count, 5);
> return pix;
> width: function(feature) {
> return (feature.cluster) ? 3 : 1;
> var layer = new OpenLayers.Layer.Vector("the name", {
> strategies: strat, // Cluster, Fixed
> protocol: new OpenLayers.Protocol.HTTP({
> url: data.url, // the URL
> format: frmt // GeoJSON
> projection: new OpenLayers.Projection('EPSG:4326'),
> styleMap: new OpenLayers.StyleMap({
> "default": defaultStyle,
> "select": {
> fillColor: "#8aeeef",
> strokeColor: "#32a8a9"
> map.addLayer(layer); // ==> map.layers[2]
> /* problem code */
> // map.layers[2].features[0] is the first point (in thousands
> of points) in this layer
> map.layers[2].features[0].style = new OpenLayers.Style({
> fillColor: "#7766ff",
> fillOpacity: 1,
> strokeColor: "#2222ff",
> strokeWidth: 1,
> strokeOpacity: 1
> context: {
> var pix = 3;
> return pix;
> the Point in this layer disappears. What I want to do is change the
> style to anything I want.
> I must be missing something or misunderstanding how styles are applied
> in OpenLayers. Thanks in advance for any and all help. I really
> appreciate it.
> Jonathan Sawyer
> Geographic Information Network of Alaska (GINA)
> University of Alaska Fairbanks
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
