[OpenLayers-Users] Change Vector Point feature class styles
dynamically.
Jonathan Sawyer
jon at gina.alaska.edu
Wed Oct 14 19:56:09 EDT 2009
Hi all,
I have a Vector layer being initialized with a default style. I am then
adding new vector features (Points) dynamically via Ajax calls and GeoJSON
data.
Anyway, if I try to apply a non-default style to a Point dynamically using
something similar to this code:
/* init code */
var defaultStyle = new OpenLayers.Style({
pointRadius: "${radius}",
fillColor: "#00ddff",
fillOpacity: 1,
strokeColor: "#008899",
strokeWidth: 1,
strokeOpacity: 1,
context: {
radius: function(feature) {
var pix = 3;
if (feature.cluster) {
pix = Math.min(feature.attributes.count, 5);
return pix;
width: function(feature) {
return (feature.cluster) ? 3 : 1;
var layer = new OpenLayers.Layer.Vector("the name", {
strategies: strat, // Cluster, Fixed
protocol: new OpenLayers.Protocol.HTTP({
url: data.url, // the URL
format: frmt // GeoJSON
projection: new OpenLayers.Projection('EPSG:4326'),
styleMap: new OpenLayers.StyleMap({
"default": defaultStyle,
"select": {
fillColor: "#8aeeef",
strokeColor: "#32a8a9"
map.addLayer(layer); // ==> map.layers[2]
/* problem code */
// map.layers[2].features[0] is the first point (in thousands of
points) in this layer
map.layers[2].features[0].style = new OpenLayers.Style({
fillColor: "#7766ff",
fillOpacity: 1,
strokeColor: "#2222ff",
strokeWidth: 1,
strokeOpacity: 1
context: {
var pix = 3;
return pix;
the Point in this layer disappears. What I want to do is change the style to
anything I want.
I must be missing something or misunderstanding how styles are applied in
OpenLayers. Thanks in advance for any and all help. I really appreciate it.
Jonathan Sawyer
Geographic Information Network of Alaska (GINA)
University of Alaska Fairbanks
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091014/ff2a530a/attachment.html
