[OpenLayers-Users] Optimal tile size for tilecache
Adrian Popa adrian_gh.popa at romtelecom.ro
Tue Oct 20 09:25:01 EDT 2009
Thank you,
I'll try with mod_python.
Another small question - is there any notable speed difference between
using tilecache (let's say through mod_python) to serve some pre-cached
tiles and using OpenLayers.Layer.Tilecache to serve the same pre-cached
tiles?
I'm thinking if I should pre-cache my whole map and use Layer.Tilecache
or if I can get away by using tilecache.py...
Has anyone done any benchmarks for these methods? If the speed
difference isn't that great, I wouldn't sacrifice the disk space...
Thank you.
Christopher Schmidt wrote:
> On Tue, Oct 20, 2009 at 09:43:35AM +0300, Adrian Popa wrote:
>> Hello Christopher,
>> Thanks for your reply.
>> I am using cgi  mode (because it's been the easiest to setup). How do
>> you recommend I run tilecache? I don't want to precache my whole map
>> because most of the zoom levels (in some areas) don't give much
>> information. I could precache some zoom levels and let the details be
>> rendered on the fly, when needed...
> Okay, using CGI is the problem. You can only get about 10 tiles/second
> with CGI, compared to hundreds with WSGI, mod_python, etc. So I recommend
> setting up mod_python or some other persistant server side process for
> serving the tiles, rathere than using CGI, which is much slower.
>> I'm not using metatiles (or at least I think I'm not using them)... I
>> don't really know what metatiles are and what they are supposed to do.
>> Maybe a point to the right documentation would be ok...
>> The tile loading process goes like this - when I change my zoom the
>> center tiles are loaded pretty quickly (even if they haven't been
>> cached) - in about half a second, but the edges of my image take about
>> ~5 seconds to load. I thought it might be a limitation of my browser -
>> on how many connections it can keep - so I added a lot of connections
>> (20 per server) both on my browser and my web server (20 processes
>> listening). The speed limitation is visible even when the tiles (for
>> that area) have been cached. I thought that by increasing the tile size
>> the browser would make fewer requests and the page would maybe load
>> faster...
>> Thanks,
>> Adrian
>>> On Mon, Oct 19, 2009 at 02:30:44PM +0300, Adrian Popa wrote:
>>>> Hello everyone,
>>>> Just wondering - what would be a good tile size to be used for
>>>> tilecache, so that the client will not do a lot of queries to the
>>>> server (seems they take quite a while), and at the same time would
>>>> not load too much information that is not used (areas of tiles which
>>>> are outside the viewable area).
>>>> My web clients use screen resolutions starting from 1200x1024 (and
>>>> usually run the page in full screen).
>>>> Right now I have tiles of 256x256 - which seem rather small and take
>>>> some time to load.
>>> I would try to understand why they take some time to load. Are you using
>>> CGI mode? (Don't.) Are you not-precaching as much as you should? Are you
>>> using metatiles? Are you not using metatiles? etc.
>>> Also, some description of 'some time' -- hundreds of milliseconds, seconds,
>>> dozens of seconds -- would probably also be appropriate.
>>>> What tile sizes do you use?
>>> 256x256. And so does Google Maps, which was doing this before most of us,
>>> and probably has a decent idea on how to make things work pretty well.
>>> -- Chris
>>>> Thanks,
>>>> Adrian
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091020/157a9589/attachment.html
