[OpenLayers-Users] Optimal tile size for tilecache
Christopher Schmidt
crschmidt at metacarta.com
Tue Oct 20 08:54:13 EDT 2009
On Tue, Oct 20, 2009 at 09:43:35AM +0300, Adrian Popa wrote:
> Hello Christopher,
> Thanks for your reply.
> I am using cgi mode (because it's been the easiest to setup). How do
> you recommend I run tilecache? I don't want to precache my whole map
> because most of the zoom levels (in some areas) don't give much
> information. I could precache some zoom levels and let the details be
> rendered on the fly, when needed...
Okay, using CGI is the problem. You can only get about 10 tiles/second
with CGI, compared to hundreds with WSGI, mod_python, etc. So I recommend
setting up mod_python or some other persistant server side process for
serving the tiles, rathere than using CGI, which is much slower.
> I'm not using metatiles (or at least I think I'm not using them)... I
> don't really know what metatiles are and what they are supposed to do.
> Maybe a point to the right documentation would be ok...
> The tile loading process goes like this - when I change my zoom the
> center tiles are loaded pretty quickly (even if they haven't been
> cached) - in about half a second, but the edges of my image take about
> ~5 seconds to load. I thought it might be a limitation of my browser -
> on how many connections it can keep - so I added a lot of connections
> (20 per server) both on my browser and my web server (20 processes
> listening). The speed limitation is visible even when the tiles (for
> that area) have been cached. I thought that by increasing the tile size
> the browser would make fewer requests and the page would maybe load
> faster...
> Thanks,
> Adrian
> Christopher Schmidt wrote:
>> On Mon, Oct 19, 2009 at 02:30:44PM +0300, Adrian Popa wrote:
>>> Hello everyone,
>>> Just wondering - what would be a good tile size to be used for
>>> tilecache, so that the client will not do a lot of queries to the
>>> server (seems they take quite a while), and at the same time would
>>> not load too much information that is not used (areas of tiles which
>>> are outside the viewable area).
>>> My web clients use screen resolutions starting from 1200x1024 (and
>>> usually run the page in full screen).
>>> Right now I have tiles of 256x256 - which seem rather small and take
>>> some time to load.
>> I would try to understand why they take some time to load. Are you using
>> CGI mode? (Don't.) Are you not-precaching as much as you should? Are you
>> using metatiles? Are you not using metatiles? etc.
>> Also, some description of 'some time' -- hundreds of milliseconds, seconds,
>> dozens of seconds -- would probably also be appropriate.
>>> What tile sizes do you use?
>> 256x256. And so does Google Maps, which was doing this before most of us,
>> and probably has a decent idea on how to make things work pretty well.
>> -- Chris
>>> Thanks,
>>> Adrian
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
