[OpenLayers-Users] objekts created with
vectorLayer.addFeature() aren't part of the insertRequest
Marco Scheuble
mail at marco-scheuble.de
Mon Oct 26 05:30:05 EDT 2009
Hi all,
problem solved!!! - And I think, I found a bug!
After adding the feature to the layer, I had to set the state of this
feature explizit to "Insert".
editableLayer.features[editableLayer.features.length-1].toState("Insert");
then it works fine!!!
I think this should be done automatically, when adding a feature to a layer
Where can I post this, so that someone can fix it?
-Marco
Marco Scheuble wrote:
> Hi all,
> the following code adds a new feature to the layer "editableLayer".
> The feature is added to the map and I can see it. But when I save this
> layer, the added feature isn't sended to the WFS-server! Features, that I
> additionally add with "OpenLayers.Control.DrawFeature" to this layer, are
> stored!?
> here is my code:
> editableLayer = new OpenLayers.Layer.Vector( 'Flächen', {
> strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy ],
> projection: gk,
> styleMap: styles,
> protocol: new OpenLayers.Protocol.WFS({
> version: '1.1.0',
> srsName: 'EPSG:31467',
> url: '/geoserver/wfs',
> featureNS : 'http://www.openplans.org/topp',
> featureType: 'poly',
> geometryName: 'the_geom'})
> var rectangle = new
> OpenLayers.Bounds(3576418,5713156,3617581,5746487).toGeometry();
> editableLayer.addFeatures(new OpenLayers.Feature.Vector(rectangle));
> editableLayer.refresh();
> And this is the request sended to the server:
> <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
> If I edit the newly added feature, and then save it, it's part of the
> request, but unfortunately inside of an update-statement :-(
> request after editing the feature:
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Update
> typeName="feature:poly"
> xmlns:feature="http://www.openplans.org/topp"><wfs:Property><wfs:Name>the_geom</wfs:Name><wfs:Value><gml:Polygon
> xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:31467"><gml:exterior><gml:LinearRing><gml:posList>3591881.3107142434
> 5724345.692857157 3602105.89285714 5725059.928571432 3606212.748214286
> 5733749.796428571 3591928.072185834 5732198.791084743 3591881.3107142434
> 5724345.692857157</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></wfs:Value></wfs:Property><ogc:Filter
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:FeatureId/></ogc:Filter></wfs:Update></wfs:Transaction>
> hopy someone can help me,
> thanks in advance,
> Marco
View this message in context: http://n2.nabble.com/objekts-created-with-vectorLayer-addFeature-aren-t-part-of-the-insertRequest-tp3871958p3890950.html
