[OpenLayers-Users] Select feature without lat/lon
Dragan Podvezanec
dragan.podvezanec at gmail.com
Wed Oct 28 04:37:56 EDT 2009
Hi all.
I don't know if this is possible: I have a page with "select" menu on the
left side in separate <div>, and map in the map <div>. Select on click works
fine. I would like the same behaviour when user selects something in select
menu. When user submits the select, he passes ID of the feature which is on
the layer which is already on the map. So, how can I make "select feature
from WMS layer on the map which has an ID=3" for example?
View this message in context: http://n2.nabble.com/Select-feature-without-lat-lon-tp3904143p3904143.html
