[OpenLayers-Users] SLD_BODY with 'like' filter
Andreas Hocevar
ahocevar at opengeo.org
Thu Oct 29 11:38:04 EDT 2009
The problem is that your filter does not have any wild cards.
If you want to find "mother" and "moocow", your value should be "mo*".
That's the string wildcard. If you want to find "daddy" and "duddy",
your value should be "d?ddy". That's the char wildcard.
Regards,
Andreas.
stash wrote:
> stash wrote:
>> Hi,
>> thanks for your answer. I will try your example out immediately.
>> But I have one question. What do you mean by string wildcard and char
>> wildcard?
>> Regards
>> stash
> I don't get an error when I start my script with your example. That is good.
> Unfortunately, instead of getting some entrys on my map I get a white sheet
> without any entries.
> What can I do now?
> That is my code for the like filter: Is there something wrong (I only want
> to show the entries which begin with "Ve")
> var filter = new OpenLayers.Filter.Comparison({
> type: OpenLayers.Filter.Comparison.LIKE,
> property: "NAME",
> value: "Ve" // * string wildcard, ? char wildcard
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
