[OpenLayers-Users] Mouse Drag Coordinates
Dave Thomas
davidt at integeo.com
Thu Oct 29 21:23:14 EDT 2009
Hi Everyone,
Hi have what I though would be a simple task but its proving to be a little
more frustrating than I anticipated.
What I need to do is get the coordinates for pan events so that I know the
coordinates of when the drag started and when it ended. The logical way to
do this as far as I thought was to listen for the mousedown (or movestart)
and mouseup (or moveend) events and get the coordinates from there. Its not
behaving the way I anticipated though. I've tried a whole bunch of different
ideas - four of which I'll list here. Surely one of these is close. I think
the first two are the closest.
I'd very much appreciate any input that may help.
Many Thanks
Dave
Method 1. Not all Events are recevied and of the ones that are I can't get
the coordinates from all of them.
click: yes
mousemove: yes
mouseup: yes
mousedown: no
movestart: yes - but coordinates recevied are NAN
moveend: yes - but coordinates received are NAN
var options =
... other settings....
eventListeners: {
"movestart": doEvent
function doEvent(event) {
var obj = this.events.getMousePosition(event);
alert(obj);
Method 2. Same results as Method 1
map.events.register("mousemove", map, function(e) {
var position = this.events.getMousePosition(e);
alert(position);
Method 3. Clicks are called but not mousedowns.
OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
defaultHandlerOptions: {
'single': true,
'double': false,
'pixelTolerance': 0,
'stopSingle': false,
'stopDouble': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handler = new OpenLayers.Handler.Click(
this, {
'click': this.doClick,
'down': this.doDown,
'mousedown': this.doMouseDown
}, this.handlerOptions
doClick: function(e) {
alert('click');
doDown: function(e) {
alert('down');
doMouseDown: function(e) {
alert('mouseDown');
Method 4. Callbacks are only received if Navigation is deactivated.
OpenLayers.Control.Drag = OpenLayers.Class(OpenLayers.Control, {
stopDown: false
this, arguments
this.handler = new OpenLayers.Handler.Drag(
this, {
'up': this.doUp,
'move': this.doMove,
'done': this.doDone
alert('down');
doUp: function(e) {
alert('up')
doMove: function(e) {
alert('move');
doDone: function(e) {
alert('done');
View this message in context: http://n2.nabble.com/Mouse-Drag-Coordinates-tp3916580p3916580.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091029/96c08efc/attachment.html
