[OpenLayers-Users] different resolutions on x/y axis possible?
Christopher Schmidt crschmidt at metacarta.com
Fri Sep 4 07:30:32 EDT 2009
On Fri, Sep 04, 2009 at 04:50:04AM -0500, Alex_vG wrote:
> Is it possible to use for the x- and the y-axis of a layer different
> resolutions?
> I want to use OpenLayers to visualize a defect map of a steel strip. The
> real dimension of the strip are appr. 2 meter x 2000 meter. That means a
> real x/y Ratio of 1:1000. I've written a php-serverscript for rendering the
> image-tiles by using the BBOX-Parameters for an WMS-layer.  For the mainmap
> i want to use the ScaleLine and the MousePosition controls with the correct
> values. In the OverviewMap i want to use a image which is compressed in the
> x direction by 100 times so it has a x/y ratio of 1:10. The overview-image
> has to be static without any zoom functionality. The pane-frame in the
> overview-map has to show the actual extend of the main-map. I hope that i
> can deal with this requirement using different x/y resolutions for my
> OverviewMap. But i dont know how...
I'm not aware of any way to do what you're asking for in OpenLayers.
-- Chris
> please have someone a good idea to help me with this task?
> PS: sorry for the bad english... (answers in german are very welcome)
> View this message in context: http://n2.nabble.com/different-resolutions-on-x-y-axis-possible-tp3578857p3578857.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
