[OpenLayers-Users] Has anyone got WFS-T working with SDE files ?
cgp carina_palanca at forcorp.com
Fri Sep 4 17:16:17 EDT 2009
Hi Ian,
Thanks for pointing me in the right direction. I'm new to OpenLayers and
GeoServer so I didn't even know that I could use that Sample Requests page
to test my POSTs.
Anyway, I did more testing and the behaviour of my application is very
random. The requests I make return valid Responses (when I put it in the
Sample Request) but it sometimes displays the features, sometimes not.
Sometimes, I'd have to zoom in and out before I see the features being
displayed. That's my issue with displaying the features.
On the other hand, the Insert and Update requests consistently return the
same error message:
java.lang.NoSuchMethodError:
org.geotools.arcsde.data.ArcTransactionState.getConnection()Lorg/geotools/arcsde/pool/ISession;
I will repost in the GeoServer forums but I hope someone here can shed light
on this as well. I'm using OpenLayers 2.8, GeoServer 1.7.6 and ArcSDE 9.3.0.
Thank you very much.
Ian Turton wrote:
> On Fri, Sep 4, 2009 at 11:14 AM, cgp<carina_palanca at forcorp.com> wrote:
>> And not just the normal shape files? I have got my SDE layers displaying
>> but
>> they are not saving at all. I tried working with normal shape files and
>> they
>> are all working fine.  Here is what I have:
> Does it work from the sample requests page of geoserver when you just
> paste in what you are sending?
> This will tell you if you are sending a bad post from OpenLayers or if
> there is something wrong with your geoserver set up (in which case you
> should ask on geoserver-users not here)
> Ian
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Has-anyone-got-WFS-T-working-with-SDE-files-tp3580580p3582543.html
