[OpenLayers-Users]  Bounds
    eoinyp
    eoinyp at yahoo.com
    Mon Sep 21 10:36:52 EDT 2009
Hi all,
Could someone please explain how to define the bounds of a map?
I want to centre my map on Ireland when it initialises, but I am having
trouble with the bounds arguments.
As I understand it, the maxExtent of the globe is (-180,-90,180,90)
A box around Ireland using the same coordinate system is (-13.5, 51.5, -4.5,
55.5)
So shouldnt I be defining my map as:
maxExtent: new OpenLayers.Bounds(-13.5,51.5,-4.5,55.5 )
This doesnt work, unsurprisingly.
I found somewhere else the bounds of the world defined as:
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,20037508, 20037508.34)
which works great, but it shows the entire globe, as I said, I want to focus
on Ireland.
What coordinate system is this? and how do I translate the area I want to
map to this coordinate system?
The variable maxResolution also seems to vary from map to map, I am not sure
what this should be set to.
The documentation doesnt give any idea of the range of appropriate values.
Thanks,
Eoinyp.
View this message in context: http://n2.nabble.com/Bounds-tp3685720p3685720.html
