[OpenLayers-Users] typename error in WFS GetFeature request
sunny74
sb.ray at hotmail.com
Tue Apr 6 15:50:11 EDT 2010
Dear Friends,
I am making a WFS Getfeature request and parsing the response of that
request using GML to add a new vector layer over a particular feature of a
layer.
The purpose is to change the color of a one or more features in a layer
So I have a WMS layer and I am making a WFS GetFeature request for getting
data to create a new vector layer over a feature on the WMS layer.
I have created 2 map files one for wms and other for wfs because I think a
single map file cannot have both the attributes(correct me if I am wrong).
My code:
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
<script type="text/javascript"
src="OL28/OL28/lib/OpenLayers.js"></script>
<script type="text/javascript">
var mapview, layer, layer1, map, popup, latlon;
var highlight_style,wfs_url;
function load() {
//OpenLayers.ProxyHost = "proxy.cgi?url=";
var lon = 77.384;
var lat = 28.389;
var zoom = 9;
map = new OpenLayers.Map('<%=map.ClientID%>', {
controls: [
new OpenLayers.Control.PanZoom(),
new OpenLayers.Control.Permalink(),
new OpenLayers.Control.Navigation()
// layer = new OpenLayers.Layer.WMS("OpenLayers
WMS",
// "http://localhost:9000/cgi-bin/mapserv.exe?",
{ map: '../htdocs/Shape/newwr1rec.map', layers: 'STATE', format: 'png' });
// layer1 = new OpenLayers.Layer.WMS("Rstations",
{ map: '../htdocs/Shape/newwr1rec.map', transparent: true, layers:
'RailwayStations', format: 'png' });
//alert(map);
layer = new OpenLayers.Layer.WMS("OpenLayers WMS",
"/cgi-bin/mapserv.exe?map=C:/Program Files/Apache Software
Foundation/Apache2.2/htdocs/Delhi/Delhi1.map", { 'layers': 'Adminbndy3',
transparent: false, format: "image/png" });
//map.addLayer(layer);
// var defaultStyle = new OpenLayers.Style({
// 'pointRadius': 10,
// 'externalGraphic': '${thumbnail}'
// select = new OpenLayers.Layer.Vector("Selection", { styleMap:
// new
OpenLayers.Style(OpenLayers.Feature.Vector.style["select"])
// hover = new OpenLayers.Layer.Vector("Hover");
//map.addLayers(layer);
// control = new OpenLayers.Control.GetFeature({
// protocol: OpenLayers.Protocol.WFS.fromWMSLayer(layer),
// box: true,
// hover: true,
// multipleKey: "shiftKey",
// toggleKey: "ctrlKey"
// control.events.register("featureselected", this, function(e)
// select.addFeatures([e.feature]);
// control.events.register("featureunselected", this,
function(e) {
// select.removeFeatures([e.feature]);
// control.events.register("hoverfeature", this, function(e) {
// hover.addFeatures([e.feature]);
// control.events.register("outfeature", this, function(e) {
// hover.removeFeatures([e.feature]);
// map.addControl(control);
// control.activate();
// map.setCenter(new OpenLayers.Bounds(76.507859, 27.613907,
78.439621, 28.941223).getCenterLonLat(), 9);
// define a blank Vector layer and add it to the map
highlight_style = { fillColor: '#99CCFF', strokeColor:
'#3399FF', fillOpacity: 0.7 };
hilites = new OpenLayers.Layer.Vector("Highlighted",
{ isBaseLayer: false, features: [], visibility: true, style:
highlight_style }
map.addLayer(layer, hilites);
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
map.addControl(new OpenLayers.Control.LayerSwitcher());
// define the WFS server which will fill requests
wfs_url =
'/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/Delhi/Delhi1_wfs.map&SERVICE=WFS&VERSION=1.0.0';
function highlightFeatures(typename, attribute, value) {
alert("wfs_url :"+ wfs_url);
var wfsurl = wfs_url + '&REQUEST=getfeature&typename=' +
typename +
'&Filter=<Filter><PropertyIsEqualTo><PropertyName>' +
attribute + '</PropertyName><Literal>' + value +
'</Literal></PropertyIsEqualTo></Filter>';
//alert(wfsurl);
OpenLayers.loadURL(wfsurl,'',null,highlight_them);
function highlight_them(response) {
// use the GML parser to turn the XML into a list
of Feature objects
var features = new
OpenLayers.Format.GML().read(response.responseText);
alert(response.responseText);
// have the Vector layer purge its feature list,
replace them with the new ones
hilites.destroyFeatures();
hilites.addFeatures(features);
hilites.setVisibility(true);
function chfeatcolor() {
//alert('Hello');
highlightFeatures('Adminbndy3', 'Polygon_nm', 'Gautam Buddha Nagar');
Now when I call the highlightFeatures() function through my code I get an
error "InvalidparametersValue" -typename does not exist.
so the error says that I given an invalid value for the typename parameter.
As you can see I have given Adminbndy3 as the typename which is the name of
the shapefile and also the wms layer.
So where am I going wrong?
What should I give as value for the typename paremeter?
Let me know if you need the wfs mapfile.
Thanks for your attention and efforts.
View this message in context: http://n2.nabble.com/typename-error-in-WFS-GetFeature-request-tp4860968p4860968.html
