[OpenLayers-Users] VectorLayer destroyFeatures doesn't work
properly?
Eric Lemoine
eric.lemoine at camptocamp.com
Sun Apr 11 10:15:44 EDT 2010
On Tuesday, April 6, 2010, gtg287y <gtg287y at gmail.com> wrote:
> I have a vectorLayer, polygonLayer, which I am calling
> destroyFeatures(polygonLayer.features) on. I can confirm that after calling
> it, the features go away in the polygonLayer.features variable. However, the
> features (polygons drawn by the DrawFeatures controller as per the example
> found at:
> http://openlayers.org/dev/examples/regular-polygons.html
> ) don't actually go away on screen (they are still drawn on the map).
Hi. I'm not sure about what's going on here, but I suspect this is
related to both addFeatures and destroyFeatures fiddling with the
features array. As a workaround you can try to register to
beforefeaturesadded (instead of beforefeatureadded) and call
destroyFeatures with no argument. Hope this helps,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
