[OpenLayers-Users] PROBLEM GOOGLE + WMS
Alessandro Gorreta
alessandro.gorreta at gmail.com
Wed Apr 7 01:45:09 EDT 2010
FOUND A STUPID SOLUTION
I've noticed the problem is extent recalculation in redraw function.
So this works temporary for me , but is strange because redraw in
singletiled / untiled layers behaviour is like a normal layer.
WHY ????
SOME IDEAS ???
openlayermap = new OpenLayers.Map('openlayermap');
var ghyb = new OpenLayers.Layer.Google("Google Hybrid",{type:
G_HYBRID_MAP, numZoomLevels: 20 , 'sphericalMercator': false});
var wms = new OpenLayers.Layer.WMS.Untiled("MYWMSLAYER","
http://89.188.137.83/mapguide/mapagent/mapagent.fcgi", {transparent: 'TRUE',
layers: 'Orbassano/Layers/Catasto Edifici' ,projection : new
OpenLayers.Projection('epsg:4326') });
*wms.redraw = function() {return;};*
openlayermap.addLayers([ghyb,wms]);
var layswitchcontrol = new OpenLayers.Control.LayerSwitcher();
openlayermap.addControl(layswitchcontrol);
openlayermap.setCenter(new OpenLayers.LonLat(xcent,ycent), 16);
THANKS..........
2010/4/6 Alexandre Dube <adube at mapgears.com>
> Hi,
> Have you tried with 'sphericalMercator': true ?
> Alexandre
> Alessandro Gorreta wrote:
>> I'm trying to do a sample thing. Put a google layer with a WMS layer from
>> mapguide server.
>> All works fine when I show viewer the first time, but when a redraw all
>> WMS layer is placed wrong.
>> If I omit singlelayer also is WRONG.
>> Some IDEAS ???
>> function openlayerinit(xcent,ycent)
>> var wms = new OpenLayers.Layer.WMS("MYWMSLAYER","
>> http://XXXXXXXX/mapguide/mapagent/mapagent.fcgi", {transparent: 'TRUE',
>> layers: 'Orbassano/Layers/Catasto Edifici' , version: '1.1.1' } ,
>> {singleTile: true} );
>> THANKS
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100407/b6b26045/attachment.html
