[OpenLayers-Users] Problem with images when put OpenLayers.js
in local path
Lisa Gaudette
lgaudette at ehealthinformation.ca
Mon Apr 12 16:52:39 EDT 2010
>From the .zip or .tar download file, you're going to want the following
files/directories in the same directory for all the default images:
OpenLayers.js
img/
theme/ (with a subdirectory of default, which has more image and css files)
style.css (not sure this is necessary)
I suspect you're missing the theme folder.
View this message in context: http://n2.nabble.com/Problem-with-images-when-put-OpenLayers-js-in-local-path-tp4864118p4892579.html
