[OpenLayers-Users] Problem with images when put OpenLayers.js
in local path
JuKiM
rifins at gmail.com
Wed Apr 14 11:24:30 EDT 2010
Yes,
I was missing the them folder!
Thanks!
2010/4/12 Lisa Gaudette <lgaudette at ehealthinformation.ca>
> From the .zip or .tar download file, you're going to want the following
> files/directories in the same directory for all the default images:
> OpenLayers.js
> img/
> theme/ (with a subdirectory of default, which has more image and css
> files)
> style.css (not sure this is necessary)
> I suspect you're missing the theme folder.
> http://n2.nabble.com/Problem-with-images-when-put-OpenLayers-js-in-local-path-tp4864118p4892579.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100414/1b5ce0db/attachment.html
