[OpenLayers-Users] Problem with images when put OpenLayers.js in local path
JuKiM rifins at gmail.com
Fri Apr 16 03:49:11 EDT 2010
Hi again,
I've seen that the arrow that should appear when you drag the map, is still
missing...
I mean, that if I load the script form openlayers, when I drag the map an
arrow with directions appears, but if I work with a local copy of the script
it doesn't appear.. Any suggestion?
Thanks!
2010/4/14 JuKiM <rifins at gmail.com>
> Yes,
> I was missing the them folder!
> Thanks!
> 2010/4/12 Lisa Gaudette <lgaudette at ehealthinformation.ca>
>> From the .zip or .tar download file, you're going to want the following
>> files/directories in the same directory for all the default images:
>> OpenLayers.js
>> img/
>> theme/  (with a subdirectory of default, which has more image and css
>> files)
>> style.css (not sure this is necessary)
>> I suspect you're missing the theme folder.
>> View this message in context:
>> http://n2.nabble.com/Problem-with-images-when-put-OpenLayers-js-in-local-path-tp4864118p4892579.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100416/6657bf9b/attachment.html
