[OpenLayers-Users] IE8 problem with VMS
Frank Broniewski
brfr at metrico.lu
Fri Apr 23 08:46:31 EDT 2010
Hello,
try to make sure that you start the map initialisation when everything
else is loaded. I used to use Jquery's $(document).ready() but needed to
switch to $(window).load() because ready() fired to early ...
Frank
Am 23.04.2010 13:56, schrieb Enrico Sartorello:
> Hi,
> I'm experiencing some troubles using OL 2.9 with IE8.
> I'm trying to add to my OpenLayers map a vector layer: it works
> perfectly on FF\Chrome, but in IE8 there's an error.
> Inside map.addLayer() call, the problem arises in VML.js, lines 147-160:
> basically, what I've found debugging is that vars this.root,
> this.vectorRoot, this.textRoot have all the attributes (even style,
> which is the one used in those lines) set to "Failed". Only
> this.rendererRoot has right values.
> The vector layer is loaded after window.onload, coupled with the opening
> of an AJAX panel.
> Using "EmulateIE7" mode doesn't solve anything.
> What can it be?
> Thanks in advance for your attention :-)
> Enrico Sartorello
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
