[OpenLayers-Users] IE8 problem with VMS
bartvde at osgis.nl bartvde at osgis.nl
Fri Apr 23 10:22:35 EDT 2010
Do you have a minimal example (HTML page) showing your problems?
Best regards,
Bart
> Moreover, the problem in Elements.js: 857 still arises.
> On Fri, Apr 23, 2010 at 4:05 PM, Enrico Sartorello <
> enrico.sartorello at gmail.com> wrote:
>> I'm rendering something like 30-40 features, all squares filled with a
>> color.
>> I don't think it's a problem of resources because if I use "EmulateIE7"
>> the
>> layer is displayed quite smoothly (but I have some other compatibility
>> issues), and also with the other browsers I don't have problems at all.
>> On Fri, Apr 23, 2010 at 3:52 PM, <bartvde at osgis.nl> wrote:
>>> How many features are you rendering, and how complex are there
>>> geometries?
>>> VML is known to be slow unfortunately, so you're easily running into
>>> the
>>> browser's limits here.
>>> Best regards,
>>> Bart
>>> > Thank you very much: now using the hosted version (r10129) I can get
>>> it
>>> > work, but with other problems.
>>> > The problem is that the vector layer loading is very very slow: IE
>>> takes
>>> > all
>>> > the CPU and runs for a very long time before rendering all. After
>>> getting
>>> > the layer rendered, the navigation on the layer is extremely slow as
>>> well.
>>> > I've tried some patches for memory leaks (
>>> > http://trac.openlayers.org/ticket/2170) without any results.
>>> > Again, this is a problem only experienced with IE8.
>>> > What should I do?
>>> > On Fri, Apr 23, 2010 at 2:46 PM, Frank Broniewski <brfr at metrico.lu>
>>> wrote:
>>> >> Hello,
>>> >> try to make sure that you start the map initialisation when
>>> everything
>>> >> else is loaded. I used to use Jquery's $(document).ready() but
>>> needed
>>> to
>>> >> switch to $(window).load() because ready() fired to early ...
>>> >> Frank
>>> >> Am 23.04.2010 13:56, schrieb Enrico Sartorello:
>>> >> > Hi,
>>> >> > I'm experiencing some troubles using OL 2.9 with IE8.
>>> >> > I'm trying to add to my OpenLayers map a vector layer: it works
>>> >> > perfectly on FF\Chrome, but in IE8 there's an error.
>>> >> > Inside map.addLayer() call, the problem arises in VML.js, lines
>>> >> 147-160:
>>> >> > basically, what I've found debugging is that vars this.root,
>>> >> > this.vectorRoot, this.textRoot have all the attributes (even
>>> style,
>>> >> > which is the one used in those lines) set to "Failed". Only
>>> >> > this.rendererRoot has right values.
>>> >> > The vector layer is loaded after window.onload, coupled with the
>>> >> opening
>>> >> > of an AJAX panel.
>>> >> > Using "EmulateIE7" mode doesn't solve anything.
>>> >> > What can it be?
>>> >> > Thanks in advance for your attention :-)
>>> >> > Enrico Sartorello
>>> >> > _______________________________________________
>>> >> > Users mailing list
>>> >> > Users at openlayers.org
>>> >> > http://openlayers.org/mailman/listinfo/users
>>> >> Frank BRONIEWSKI
>>> >> METRICO s.à r.l.
>>> >> géomètres
>>> >> technologies d'information géographique
>>> >> rue des Romains 36
>>> >> L-5433 NIEDERDONVEN
>>> >> tél.: +352 26 74 94 - 28
>>> >> fax.: +352 26 74 94 99
>>> >> http://www.metrico.lu
>>> >> Users mailing list
>>> > Enrico Sartorello
>>> > Users mailing list
>> Enrico Sartorello
> Enrico Sartorello
