[OpenLayers-Users] IE8 problem with VMS
Enrico Sartorello
enrico.sartorello at gmail.com
Fri Apr 23 11:30:31 EDT 2010
I'm afraid I can't show the code I'm working on. Even creating a simple
example isn't that easy because it's quite long and complicated.
On Fri, Apr 23, 2010 at 4:22 PM, <bartvde at osgis.nl> wrote:
> Do you have a minimal example (HTML page) showing your problems?
> Best regards,
> Bart
> > Moreover, the problem in Elements.js: 857 still arises.
> > On Fri, Apr 23, 2010 at 4:05 PM, Enrico Sartorello <
> > enrico.sartorello at gmail.com> wrote:
> >> I'm rendering something like 30-40 features, all squares filled with a
> >> color.
> >> I don't think it's a problem of resources because if I use "EmulateIE7"
> >> the
> >> layer is displayed quite smoothly (but I have some other compatibility
> >> issues), and also with the other browsers I don't have problems at all.
> >> On Fri, Apr 23, 2010 at 3:52 PM, <bartvde at osgis.nl> wrote:
> >>> How many features are you rendering, and how complex are there
> >>> geometries?
> >>> VML is known to be slow unfortunately, so you're easily running into
> >>> the
> >>> browser's limits here.
> >>> Best regards,
> >>> Bart
> >>> > Thank you very much: now using the hosted version (r10129) I can get
> >>> it
> >>> > work, but with other problems.
> >>> > The problem is that the vector layer loading is very very slow: IE
> >>> takes
> >>> > all
> >>> > the CPU and runs for a very long time before rendering all. After
> >>> getting
> >>> > the layer rendered, the navigation on the layer is extremely slow as
> >>> well.
> >>> > I've tried some patches for memory leaks (
> >>> > http://trac.openlayers.org/ticket/2170) without any results.
> >>> > Again, this is a problem only experienced with IE8.
> >>> > What should I do?
> >>> > On Fri, Apr 23, 2010 at 2:46 PM, Frank Broniewski <brfr at metrico.lu>
> >>> wrote:
> >>> >> Hello,
> >>> >> try to make sure that you start the map initialisation when
> >>> everything
> >>> >> else is loaded. I used to use Jquery's $(document).ready() but
> >>> needed
> >>> to
> >>> >> switch to $(window).load() because ready() fired to early ...
> >>> >> Frank
> >>> >> Am 23.04.2010 13:56, schrieb Enrico Sartorello:
> >>> >> > Hi,
> >>> >> > I'm experiencing some troubles using OL 2.9 with IE8.
> >>> >> > I'm trying to add to my OpenLayers map a vector layer: it works
> >>> >> > perfectly on FF\Chrome, but in IE8 there's an error.
> >>> >> > Inside map.addLayer() call, the problem arises in VML.js, lines
> >>> >> 147-160:
> >>> >> > basically, what I've found debugging is that vars this.root,
> >>> >> > this.vectorRoot, this.textRoot have all the attributes (even
> >>> style,
> >>> >> > which is the one used in those lines) set to "Failed". Only
> >>> >> > this.rendererRoot has right values.
> >>> >> > The vector layer is loaded after window.onload, coupled with the
> >>> >> opening
> >>> >> > of an AJAX panel.
> >>> >> > Using "EmulateIE7" mode doesn't solve anything.
> >>> >> > What can it be?
> >>> >> > Thanks in advance for your attention :-)
> >>> >> > Enrico Sartorello
> >>> >> > _______________________________________________
> >>> >> > Users mailing list
> >>> >> > Users at openlayers.org
> >>> >> > http://openlayers.org/mailman/listinfo/users
> >>> >> Frank BRONIEWSKI
> >>> >> METRICO s.à r.l.
> >>> >> géomètres
> >>> >> technologies d'information géographique
> >>> >> rue des Romains 36
> >>> >> L-5433 NIEDERDONVEN
> >>> >> tél.: +352 26 74 94 - 28
> >>> >> fax.: +352 26 74 94 99
> >>> >> http://www.metrico.lu
> >>> >> Users mailing list
> >>> > Enrico Sartorello
> >>> > Users mailing list
> >> Enrico Sartorello
> > Enrico Sartorello
Enrico Sartorello
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100423/ca05d35e/attachment.html
