[OpenLayers-Users] Vector rotation issues with 2.9
Lennox Antoine lxnyce at gmail.com
Tue Apr 27 09:56:39 EDT 2010
I tried 2.9 and I ran into similar issues as well. I finally got around to
stripping it down, so here are two simple examples showing it :
2.8 : http://vizure.net/temp/ol/rotation_2_8.html
2.9 : http://vizure.net/temp/ol/rotation_2_9.html
Both are exactly the same, except for which version of the library is in
use.
In 2.8, click the icon, then drag it around. Everything works fine.
In 2.9, click the icon, then try to drag it around. For me it starts to
rotate and move in the opposite direction. If I zoom in, it also goes to
random places and does not stay where it's pinned.
Lennox
On Tue, Apr 27, 2010 at 8:30 AM, pedro hernandez <
pedrohernandez830 at gmail.com> wrote:
> Something similar happens to me when I tried 2.9 version.
> I'm using Vector Layer with one vector of Geometry Points. If I use circle
> in graphicName of Style Map it puts in a good position but If I instead I
> use triangle with rotation propierty it puts in a bad postion.
> In my case this  happens in Mozilla Firefox (I'm using 3.5 version) and not
> in IE8.
> On Tue, Apr 27, 2010 at 4:14 AM, Robert Sanson <SansonR at asurequality.com>wrote:
>>  It looks to me like the labels are keeping their correct geographical
>> positions, but the vector symbols (arrows) are not.
>> Robert
>> >>> John McGuire <jamcguir at ncsu.edu> 27/04/2010 7:22 a.m. >>>
>> All,
>>    I am creating an interface to visualization weather information.
>> However, within the past week, we have noticed that when a user zooms in
>> and out with wind arrows drawn, the vector is separate from its label,
>> and nowhere near its intended direction. I have found that v2.8 does not
>> have this issue. Playing with the code, it seems that the rotation in
>> v2.9 is the problem, and also exists for the default shape of triangle.
>> If anyone would have any further insight to this problem, I would be
>> greatly appreciative.
>> I have included links below to demonstrate the difference.
>> 2.9 map:
>> http://sco-server6.meas.ncsu.edu/webtest/workspace/cronos/map/?ol=2.9
>> 2.8 map: http://sco-server6.meas.ncsu.edu/webtest/workspace/cronos/map/
>> Thank you all for your help,
>> -John
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> This message has been scanned for malware by SurfControl plc.
>> www.surfcontrol.com
>> Users mailing list
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100427/e6dc8a53/attachment.html
