[OpenLayers-Users] labels on feature help
Marc Jansen
jansen at terrestris.de
Mon Aug 2 15:36:49 EDT 2010
Hi ulao,
where did you define the variable 'layer' used in
map.addLayer(layer);
Regards,
marc
Am 02.08.2010 18:01, schrieb ulao:
> I tried to make a simple app and now I have a strange issue. See the alert.
> The strange thing is this code works in the live example so it must be a
> typeO or html error I can not spot.
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>test</title>
> <script src="OpenLayers.js"></script>
> <script type="text/javascript">
> document.write('<script type="text/javascript"
> src="http://maps.Google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhT2yXp_ZAY8_ufC3CFXhHIE1NvwkxTS6gjckBmeABOGXIUiOiZObZESPg"></scr'
> + 'ipt>');
> var map,glayer,lineLayer;
> function init(){
> map = new OpenLayers.Map('map');
> glayer = new OpenLayers.Layer.Google( "Google Streets" , {type:
> G_NORMAL_MAP ,numZoomLevels: 22 });
> map.addLayer(glayer);
> map.addLayer(layer);alert("ie wont get here, ff does? Even
> though ff does it still didnt create the layer right");
> var points = new Array(new OpenLayers.Geometry.Point(17.99,59.3) )
> points[1] = new OpenLayers.Geometry.Point(1,1)
> points[2] = new OpenLayers.Geometry.Point(100,100)
> var obj = new OpenLayers.Geometry.LineString(points);
> var newFeature = new OpenLayers.Feature.Vector( obj );
> newFeature.style =
> strokeWidth: 14,
> label: "test",
> fontColor: "green",
> fontSize: "20px",
> fontFamily: "Arial",
> labelAlign: "cb",
> fillOpacity: 1
> lineLayer.addFeatures(newFeature)
> map.setCenter(new OpenLayers.LonLat(17.99,59.3) );
> //map.zoomTo(10);
> </script>
> </head>
> <body onload="init()">
> <div id="map" class="smallmap"></div>
> </body>
> </html>
