[OpenLayers-Users] OpenLayers.Filter.Comparison.LIKE and singleChar
Ian Turton ijturton at gmail.com
Thu Aug 5 11:54:55 EDT 2010
On Thu, Aug 5, 2010 at 11:38 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> Eric's patch won't solve the problem, because the input to the filter will then be "0.2" instead of ".2".
> Arnd, can you please create a ticket? This behavior was introduced by http://trac.openlayers.org/changeset/8927, and I think it would be better to cast in filter.evaluate rather than in format readers.
Isn't the fix to simply put ".2" in the literal instead of .2 which is
treated as a number? I know we had this problem in GeoServer
(GeoTools) with interpreting literal values that are ambiguous.
Ian
Ian Turton
