[OpenLayers-Users] OpenLayers.Filter.Comparison.LIKE and
singleChar
Arnd Wippermann
arnd.wippermann at web.de
Thu Aug 5 13:05:06 EDT 2010
As I understand, the patch solves the problem, that the SLD will be created.
Therefor I can use it for request WFS GetFeature. But as the SLD reader use
the filter to interpret the rule, it will use "0.2" instead of ".2" and
causes to use the ElseFilter and styles the features in the wrong way?
The OGC filters are an interesting subject. Not only OpenLayers fails. Also
with MapServer there are some issues.
Arnd
-----Ursprüngliche Nachricht-----
Von: Andreas Hocevar [mailto:ahocevar at opengeo.org]
Gesendet: Donnerstag, 5. August 2010 17:38
An: Eric Lemoine
Cc: Arnd Wippermann; users at openlayers.org
Betreff: Re: [OpenLayers-Users] OpenLayers.Filter.Comparison.LIKE and
singleChar
Eric's patch won't solve the problem, because the input to the filter will
then be "0.2" instead of ".2".
Arnd, can you please create a ticket? This behavior was introduced by
http://trac.openlayers.org/changeset/8927, and I think it would be better to
cast in filter.evaluate rather than in format readers.
Regards,
Andreas.
On Aug 5, 2010, at 17:31 , Eric Lemoine wrote:
> On Thu, Aug 5, 2010 at 2:28 PM, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
>> Hi Eric,
>> thanks for the reply and the hint. It's a more complex situation.
>> It's not a problem with the filter, but with
OpenLayers.Format.SLD().read:
>> I create a SLD and apply it to a vector layer
>> var formatSLD = new OpenLayers.Format.SLD();
>> var sld = formatSLD.read(theSLD_BODY);
>> It works perfect, but only the LIKE-filter with "." works not.
>> The filterpart from theSLD_BODY for this case looks like
>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>> <ogc:PropertyIsLike wildCard="*" singleChar="." escape="!">
>> <ogc:PropertyName>indice</ogc:PropertyName>
>> <ogc:Literal>.2</ogc:Literal>
>> </ogc:PropertyIsLike>
>> </ogc:Filter>
>> The ".2" enters the function OpenLayers.Filter.Comparison.value2regex
>> as 0.2 as number (typeof this.value -> number ?!)
>> and causes the error "this.value.replace is not a function".
>> if I overwrite the function by adding
>> this.value=this.value.toString(), then the error vanishes, but the
>> applied rule to the vector layer doesn't result in a correct style.
>> Appling the same SLD to the WMS layer, shows the correct style. It
>> seems, the SLD is correct.
>> I remember a case with labels like 02.09, that change to 2.09.
>> Perhaps the same issue.
>> If you have any hint, where to further look?
> Does the attached patch solve the problem?
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> <patch>_______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
