[OpenLayers-Users] Can I output my layers/map in SVG?
Adam Ratcliffe
adam at prema.co.nz
Fri Aug 6 18:18:26 EDT 2010
If your map server also provides a WFS service, such as GeoServer does, you can fetch your map features as structured data and render them as vectors on the client. You can see an example here: http://openlayers.org/dev/examples/
Is that what you're after?
Cheers
Adam
On 7/08/2010, at 3:02 AM, Planet)x wrote:
> I have only recently started using open layers and have managed to add
> several layers from my WMS and display them as vector png images. Is it
> possible to output the layers as SVG format? I am trying to find a good
> example through the forums/messages but was unable to find a good
> example/tutorial. Appreciate any assistance or a point in the right
> direction for rendering my layers in SVG format.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-I-output-my-layers-map-in-SVG-tp5380915p5380915.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
