[OpenLayers-Users] Customizing OpenLayers JS file
Franz Buchinger
fbuchinger at gmail.com
Wed Aug 11 04:21:34 EDT 2010
You don't need to run build.py as you've already downloaded a customized
openlayers build.
Your problem looks like a theme/css issue, your openlayers build can't find
the css files for the map theme.
Make sure your customized_openlayers.js is in the root directory of
openlayers (with the subdirectories img and theme).
Franz
2010/8/11 monajain62 <life.monajain at yahoo.com>
> Hi Chris,
> So after i customize my openlayers.js file using
> http://openlayerer.appspot.com/ http://openlayerer.appspot.com/ i need to
> run build.py file right?
> Do i need to put the customised JS file in the lib folder and then deploy?
> http://osgeo-org.1803224.n2.nabble.com/Customizing-OpenLayers-JS-file-tp5389023p5411002.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100811/d1bab836/attachment.html
