[OpenLayers-Users] transparent & WMS.POST
    Sascha Müller
    olaiya at arcor.de
    Fri Aug 13 05:37:28 EDT 2010
I use:
Openlayers: 2.9
GeoExt: trunk
GeoServer: 1.7.7
I used following code:
var addlayer = new OpenLayers.Layer.WMS.POST(
                         layers_array[i][0],
                         layers_array[i][1],
                             layers           : layers_array[i][2],
                             format           : 'image/png',
                             transparent      : true
                             isBaseLayer      : layers_array[i][3],
                             visibility       : layers_array[i][4],
                             buffer           : 0,
                             singleTile       : true,
                             transitionEffect : "resize"
                     map.addLayer(addlayer);
If I try to set the transparency of one these layers, the transparency
is not that what I expected. Only the color changed to to more brigther.
With this code:
var addlayer = new OpenLayers.Layer.WMS(
                         layers_array[i][0],
                         layers_array[i][1],
                             transparent      : true
                             buffer           : 0,
                             singleTile       : true,
Everything works how it should. The transparency looks transparency.
Is this behavior intended or a bug?
regards,
Sascha
